AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Draw Pipe in Elevation View
2 REPLIES 2
mcawson
692 Views, 2 Replies
I am working on a piping diagram and when I change to a side or front/back view, I am unable to draw pipe horizontally or vertically (it runs off at an angle).  What setting am I missing to allow me to draw in the elevation view?  As an example, I want to draw a 12" diameter steam header 3 feet off the ground with multiple 6" valves coming off the top going to various connections.
I just did something and now I can't even draw them parallel to the XY plane in the top view.  Whatever I draw ends up at an angle into the Z plane.  Help!
2 REPLIES 2
mcawson
in reply to: mcawson
Attached is what I am talking about.  I restarted MEP and began with a new template.  Even a short section of pipe is not showing up correctly...it's on an angle in the Z direction, resulting in the pipe ends showing.  What did I change to make it do this?
JoeVernice
@mcawson
Check the slope in the properties palette.
JMV
