Cursor drags well trying to use any line circle, rec or demension command.
RidgewayPlumbing
RidgewayPlumbing
this only happens for some of my dwg drawings expecially larger files.
Victoria.Studley
Hi @RidgewayPlumbing,
Thank you for posting your question here in the community. Could you post a Screencast and/or a sample file where this issue is occurring?
If the issue is file-specific, you may want to start by cleaning up the affected file(s). You can do that by using the tips in this article.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
CADmonkey_UK_Building_Services
I think you're describing 'cursor lag'. My first reaction would be to disable as much eye-candy as you can find in the Options dialogs. The kind that happens as the mouse moves over things. Selection preview, anything with the word 'dynamic', tool tips, polar vector tracking lines, mini floating command prompts at the cursor, lineweight displays.
If Hardware Accel. is disabled, try enabling it. If it is enabled, try disabling it.
I've been using Acad since rel.12 and I've always scrapped the increasing amount of eye candy as soon as I installed the latest version.
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
