COPY TO CLIPBOARD
COPY TO CLIPBOARD
centurymechanical
COPY TO CLIPBOARD
centurymechanical
When trying to copy to clipboard there is a error, saying copy to clip board failed.
Mark
shiny.stephen
Which version of AutoCAD MEP you are using? There was a known issue in AutoCAD MEP 2010 which was rectified in web update 2.
Shiny Stephen
Support Specialist
Product Support
centurymechanical
We are using 2012.
I get the same error "Copy to clipboard failed"
I'm using version 2012
Any news/tricks on solving this issue?
Joshua.Benoist
Do you have a 3rd party application like Quickpen, CADDUCT or EastCoast CAD?  With a "Proxy Object" in the file, objects cannot be copied to the clipboard.  The goes for Civil 3D objects wo the object enabler as well.
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Thanks for the information.
It may be the reason you describe, but I'm not really sure what the file contains since it is a file produced by client and sent to us. I'll be more aware of this next time I recieve AutoCad files.
//Annika
Had the same problem and ran across a quick work-around:
In my case I could use the ACAD COPY command (CO) but not the COPYCLIP command (CTRL-C)
I simply copied the whole drawing using COPY and moved off to the side. The resulting copy could be copied to the clip-board without any problem.
I'm using ACAD2013
