Convert Solidworks drawing to autocad
Is it possible to convert Solidworks drawing to an Autocad drawing?
I'm using Autocad MEP 2015
Steps I took:   I us the import command,   then sellect the solidworks file,   then an icon appears on the lower right of the screen,  when I try to insert the file nothing happens. Please refer to attached files.
Laks-Autodesk
Have you tried to import this file in a NEW drawing and try to zoom to the extents of the drawing? If you're still unable to see the imported geometry it could be a file specific issue.
Lakshminarasimhan Seshadri
Thanks Lakshminarasimhan Seshadri Worked like a charm!
 Hi again Lakshminarasimhan Seshadri
I tried to import another a much larger file with no success (see attached) 3MB compared to 152KB and with a different extention sldasm as apposed to sldprt.
Any idea's?
