Convert number as text to number as real or integer
goyete
goyete
Hello, I have a Property with a text field where I can put numbers or for example "-".
I want to make a schedule table with this field and then a formula column.
I want to get 0 if the field is "-" and the number if it isn't "-". My problem is that the data inserted in the field is saved as text, not as number. Is there any way to convert a string text (for example "45") to a number (45).
Thanks!!
Keith.Brown
Take a look at Look at cint() or cdbl(). They will convert a number to an integer or a double which is essentially a reall number.
goyete
Thanks Keith, cint("field") works fine for me!
it didnt work for me
you can give me example?
example
