where is the autocad toolbar?
Message 1 of 16
hi ~ 🙂
I am using autocad mechanical 2018
after intallation and itry toolbar setting
oh mygod..
autocad menu toolbar is gone
Other computers have the same behavior
2017 version  is autocad tool bar existence
Replies (15)
Message 2 of 16
Vinayv4v
Try to reset your AutoCAD Mechanical profile to default settings and check if the issue is resolved.
Cheers,
Vinay Vijayakumaran
Message 3 of 16
thx.... but reset is not work
this issue is  install - >no thouch -> normal  run
i think about that mechanical 2018  version bug
can anybody test mechanical 2018?
plz
Message 4 of 16
imadHabash
would you try to change workspace and see if any differences. also check from Tools >> Toolbars >> AutoCAD .
Imad Habash
Message 5 of 16
mechanical version is different
autocad menubar
Message 6 of 16
imadHabash
>> mechanical version is different <<
so try to post your issue here. >> Click <<
Good Luck.. 🙂
Imad Habash
Message 7 of 16
pinaki.rajak
 Can you able to see workspace icon at right corner of your AutoCAD window like the image shown (Red Circle).
If yes, click required setting like AutoCAD Classic- Migrated from AutoCAD 2017
after that set that worspace as default and check, you will able to see the AutoCAD tool option.
Message 8 of 16
TheCADnoob
tyr loading the tool bar manual and see if you can.
-TOOLBAR
If you cant load the one you are looking for you may have to copy in the CUIX
CADnoob
Message 9 of 16
no migration
install -> no touch -> no migration -> no setting
may be autocad cuix no loading
2018 bug???? or korean vesion bug?
Message 10 of 16
pinaki.rajak
I can see the customization option there in your snap, click that option, a window will open "Customize User Interface".
Go to "Transfer" Tab
Load a previous configuration (*.cuix)
Browse path : C:\Users\folder of your name\AppData\Roaming\Autodesk\AutoCAD 2017\R21.0\enu\Support
do necessary steps if it asked to do by pop-up windows if any.
Now press apply & OK.
Check again and select interface which migrated from previous version. In this current UI, you will see the AutoCAD tools.
Message 11 of 16
Go to the below location and delete the folder “Autocad
1.C:\Users\USERID\AppData\Local
2.C:\Users\USERID\AppData\Roaming
Go to "registry editor" and delete the entries of "AutoCAD" like the attached image.
You will get the resetted new AutoCAD.
Regards
Ananthakumar
Message 12 of 16
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I have tested AutoCAD Mechanical 2018, the AutoCAD Toolbar set is not available on the English version either, and I am not able to call the individual Toolbars up via the -TOOLBARS command that would normally be found in the AutoCAD set.
Thank you for pointing this out, I will log the issue with development.
All the very best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 13 of 16
I have the same problem, Toolbars is missing in the Tools dropdown.
Message 14 of 16
TheCADnoob
Message 15 of 16
I am looking to load the vanilla dimension toolbar into ACADM 2020.. Has this been addressed yet?
Message 16 of 16
TheCADnoob
Tool bars are no longer available as an out of the box setup. you can get them back easily if that is what you are talking about. https://www.cad-notes.com/autocad-script-to-create-classic-workspace-automatically/
Are you looking for the vanilla Ribbon? if so you can switch to the "drafting and annotation" work space by clicking the sprocket at the lower right hand of the screen. https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoC...
CADnoob
