Way too many lines, and gridlines, when using revolve command
tcharbonneau
tcharbonneau
This just started happening.  Autocad Mechanical 2023.  Simple 3D solid modeling.  Was doing this all day yesterday and today, and was fine until now.
It started out with revolving a shape for an input adapter for a gearmotor.  But then I tried drawing around it manually with fresh lines.  Then I tried revolving a simple rectangle drawn from scratch, and it still does this.  I even tried starting a new drawing, and it still does it.
An absolute ridiculous amount of lines on a straight wall cylinder.  And even a grid of lines on the flat ends.
How do I get rid of this so it goes back to looking clean?
Thanks.
Keshava_Murthy
Hi @tcharbonneau,
Thanks for your question.
I understand that you are looking a way to modify the visual style (which is currently in Wireframe style) of your 3D model. Please let me know if I am mistaken.
You can utilize the options available on the screen or in the command line: VS or VSCurrent to adjust the visual style of the model as needed.
Please click ACCEPT SOLUTION if my post helps in solving your issue or answering your question.
Keshava Murthy
AutoCAD Mechanical Team
