toolbar option missing from Tools Menu
alashwellZYSS6
alashwellZYSS6
The toolbar option isn't listed in the Tools menu? Trying to add my custom toolbars I've been using for twenty years.
This is for Autocad Mechanical 2019. It is working for autocad electrical 2019 and Autocad 2019.
pendean
Community Legend
Community Legend
TOOLS menu?
alashwellZYSS6
Yes,IMG_4795.JPG Tools on the menu bar is missing the toolbars option.    This Electrical 2019, Mechanical it's missing
pendean
Community Legend
Community Legend
Which workspace are you in?
Is the problem present in the other workspaces?
CUI command
Expand the Toolbars Section
Are there any to select and turn on?
alashwellZYSS6
I'm in the Mechanical Workspace. Tried the other, same thing.
In the CUI,  Toolbars is missing in the       menus
        +Tools
When I look at the same +Tools group Toolbars is included in Acad Electrical 2019 and Standard Acad 2019.
Tried to copy it in won't let me.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @alashwellZYSS6,
I see that you are visiting as a new member to the AutoCAD Mechanical forum. Welcome to the Autodesk Community!
The Toolbars option is not included in AutoCAD Mechanical. It may have been included in the 2014 release, but was removed when AutoCAD Mechanical added the Ribbon.
You can access toolbars from the -TOOLBARS command, type in the specific tool bars, or All. The available toolbars can be found in the CUI here:
If you are not seeing this, I would recommend checking that you have the latest updates installed. If you suspect a corrupted install, you could try reset to defaults.
If a post was helpful, Likes are always welcome.
Please Accept As Solution any post(s) that answer your question or solve the problem.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @alashwellZYSS6,
I am checking back to see if my post answered your question. Please add a post letting the community know.
All the best,
Cheryl Buck
