Setting a snap filter as default
Can the filter for snapping to a dimension be set as the default so I don't have to reset the filter for each NEW drawing? Please advise.
[The subject line of this post has been edited for clarity by cheryl.buck from: Can't snap to a dimension...
Instructions from previous post that are referenced here:
To snap to dimension lines,try the following:
1. Invoke Amoptions;
2. Click on AM:Preference tab;
3. Select Snap Defaults > click on Filters;
4. Uncheck Dimension in the Entity filter.]
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD Mechanical forum. Welcome to the Autodesk Community!
As far as I know, snap filter is a general setting so unless it has been checked in an existing drawing, if you uncheck the box, all new drawings should be created with it unchecked.
[This post has been edited for clarity by cheryl.buck]
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Sridhar-Autodesk
Hi
Can you open the template file and make the changes so that it is applicable for all new drawings created thereafter?
Sridhar Subramani
Senior Product Owner
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if you still need help with this post.
All the best,
Cheryl Buck
Morning Cheryl,
I sent a reply yesterday indicating that I have basically answered my own question. One thing I do find is that this forum seems a bit repetitive and awkward to use. Perhaps when I get a bit more use from it things will become clearer.
Have a great day.
Heath
cheryl.buck
Autodesk Support
Autodesk Support
Hi Heath [@Anonymous],
I am very glad you were able to resolve the snap filter issue. I apologize though, your reply does not seem to have been saved to the thread. It would be great if you would repost how you solved the issue. I would be happy to mark it As the Solution and you will receive credit for it.
I agree, forums do take a little getting used to if you are new to them, but they can be a great resource for troubleshooting and learning. I hope to see you in the forums in the future.
All the best.
Cheryl Buck
