save problem
save problem
save problem
Dear All,
I having a problem in my Autodesk Mech. 2011,
when ever i open a existing drg. from my pc , and I hit the save button or ctrl+s the dilouge box opens, it is not opening my file path(see attached file u2) insted of it gose to the path of template folder (see attached file u1)
why it happen,
Please give me solution,
Walekar Dattatraya P.
Sridhar-Autodesk
Hi
set system variable REMEMBERFOLDERS value to 1
Hit Save button>>From the "files of type" dropdown select AutoCAD Mechanical 2011 *.dwg option and browse to the location you want to save the drawing to.  Subsequent saves should take you to the same location next time.
Let me know if this works?
Sridhar Subramani
Senior Product Owner
