Reversing the direction of array
Yashasvi23481
Yashasvi23481
Hi All,
    Working on AutoCAD Mechanical 2018, I want to know how can I reverse the direction of array using path or rectangular ? One of the methods I learnt online is to enter distance in negative if the direction is opposite of what you want. But can you hold the grip/arrow and reverse it ? when you hit array and select path you are provided with multiple options. Even when I select a side where I want array, it sometimes chooses opposite direction.
               Let me know if there is any other/ direct method to reverse the direction of array without entering negative value.
Yash
Sridhar-Autodesk
Hi Yash,
You may change the array direction by selecting the arrow.  Please see the screencast attached.
https://autode.sk/2lvSstI
Let us know if this helps.
Sridhar Subramani
Senior Product Owner
binaya.paudelL8YWS
Thank you for your input. However, it doesn't work for me while reversing the "Path" array type.
