Hi Expert team,
Is it possible to create iso view from 2d View in AutoCAD just like we do in Inventor ? There are tabs in Inventor like Parametric and Content which talks about constraints and FEA along with views from Inventor in Home tab.
So if I have 2d drawing can I project views ?
Thanks for help in advance.
Yash
Hi Expert team,
Yash
Solved by VinodBalasubramanian. Go to Solution.
Hi Yash,
In Mechanical you can do it using the drawing views, type AMDWGVIEW and check the following. Will this help you ?
Hi Yash,
Hi Vinod,
Thank you. I will work on it. If you create 2D projected views, how can other feature be shown ? Usually in 3D package like Inventor the model is in 3D so when you project, all feature are shown in 3D iso view. But if I draw just rectangle and there are cuts or hole in other side, how does 3D projected view show it ? Do you import model from Inventor using base view ?
Yash
Hi Vinod,
Yash
Hi Yash,
Use the model documentation to create drawing views from Inventor,
Hope that helps.
Hi Yash,
Hope that helps.
