AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Problem with shader on curved surfaces - Installation Drawing - Mechanical 2011
3 REPLIES 3
373 Views, 3 Replies
Hi everybody,
   as you can see in the attached image, in some surfaces apperas the "triangles" of the surface and in others not. Please, do you know any command or variable which could resolve this?? I would like to have all the surfaces smoth, without triangles.
Tags (3)
3 REPLIES 3
Nobody has this problem???
michaelsu
It would be helpful if you post a sample drawing for further look. Or you can send me (Email: zhiyuan.su@autodesk.com) the drawing.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
in reply to: michaelsu
Here is a zipped dwg to test.
Thanks in advance and kind regards
Sam
”Boost
