Problem with ATTEDIT failing to update attribute values
Macumazahn
Macumazahn
I am experiencing similar problems with double click editting on titleblocks (so dynamic blocks). Really editing any text attributes in blocks. I also cannot double click to edit a block. I've tried tweaking the DBLCLICK, manually and in Options, I've tried saving down, saving it back as 2018, read all the forums...
This has happened ever since I installed Mech 2018 a few weeks ago.
I even tried adding double click functions in the CUI.
I even erased the ones (in my CUI) that are there and are simply lies. LIES I tell you! And obviously replaced them. Edit attribute, ampower... tried tweaking all these.
I couldn't even double-click to edit text, but that went away for some reason. it comes back occasionally...
Also, every time I open Mech 2018, it has defaulted back to the Mechanical profile and not my preferred <<Vanilla>> profile. I tried changing those settings too without luck.
This post was split from another thread by john.vellek
lakshmankumar.satya
It is possible one of your system variables got changed. Try typing BLOCKEDITLOCK, and change the value to 0.Hope that helps.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Macumazahn,
I am checking back to see if you were able to resolve your issue with the great post by @lakshmankumar.satya.
Also, if you have not done so already, please install the latest updates. All current updates are available through your Autodesk Account under the Manage tab.
If a post was helpful, Kudos are always welcome.
Please also select the Accept as Solution button on any posts that helped solve your issue or answered your question.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
