Pattern a rectangle around a spline using ARRAYPATH
Hi all. Disclaimer: I don't get to use ACad much, as my company primarily uses Inventor. However this project will be handled much easier with ACad.
I've been fighting with this for hours. I have a rectangle that needs to be patterned around a spline curve. The catch: the mid-point of both rectangle ends need to be on the curve.
Suggestions please?
Jason.Rugg
@AnonymousTry using parametric constraints to constrain the end of the first rectangle to the spline the way you would like it and then try to pattern it.
@Jason.Rugg
Thanks for the suggestion, but unfortunately it doesn't work either. The ARRAYPATH function only seems to consider the location of the base point with respect to the spline curve.
