New Install: Vault Buttons Not Appearing On Panels (ACM 2026, Vault Pro 2025)
jimm_motyka_777
jimm_motyka_777
I'm looking for some assistance on this.  I went and loaded the menu in for Vault after the ACM 2026 install.  Although the tab shows up, the buttons on the panels do not appear.  Does anyone have a solution?
Keshava_Murthy
Hi @jimm_motyka_777,
Can you please try the steps mentioned in this article and check if this solution works for you.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Vault-ribbon-image...
additional links if required
 https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Vault-ribbon-does-...
Please click ACCEPT SOLUTION if my post helps in solving your issue or answering your question.
Keshava Murthy
AutoCAD Mechanical Team
jimm_motyka_777
I did that and still am not seeing the buttons on the ribbon.  I even closed the program and reopened it, just as a test.
I'm mapped to the correct support file in 2026 (vaac.cuix).  I do appreciate the reply, yet am still seeing the same result.
jimm_motyka_777
I am one level deeper and it appears that the commands are showing, yet when selected, I don't have the ability to Apply the commands I'm choosing.
Hopefully this little nugget gets me closer.
