- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
I'm trying to import a STEP file to AutoCAD but keep getting a "Modeling Operation Error: Access violation" message after trying any command. After 2 or 3 commands AutoCAD crashes with the following message:
"Internal Error: !dbobji.cpp@8016: eGeneralModelingFailure"
If I try to save as a .DWG, I get the message: "One or more objects in this drawing cannot be saved to the specified format. The operation was not completed and no file was created."
Crash message says: "FATAL ERROR, Unhandled Access Violation Reading 0x2ed6e48 Exception at 24962f7ch"
Attached you'll find a command log and the most I ca do with the file before AutoCAD crashes. Any hints on how to fix this are much appreciated. Cheers!
GP
