Hello.
I have been working in autocad for couple of years, but i never used my title block in Layout. My routine of work has been just making a model on 1:1 ratio and scale the Title Block according to that and fit that into it.
Now a days i have a project in may hand that has got some drawings in the formate that therer is no Title Block in the Medel Space rathe it is in Layout Space. I can't change and/or scale the title block as it is restricted by the contractor. That i liked the most efficient way to create a Drawing.
Now, how can i make such Title Block and do my work in future in this mode?
P.S. I have gone through many tutorials abt making *.DWT tempelates, but i cant insert in the Layout Tab. In general i can't make or even insert the Title Block like i said before. Please help me with this issue.
Pictures are attached for reference.
NABILBAIG.
Are you using AutoCAD Mechanical? I cannot possible cover that topic through the forum.
This is a very thorough video tutorial. Although it is long, it is well worth the time if you are new to creating titleblocks.
https://www.youtube.com/watch?v=_qSYW_KE_SU.
Once you have a good understanding of creating your titleblock to suite your needs, (comany info and standards), this one is very good at explaining Mechanical titleblocks. They are different!
good luck and please ask more questions if you have specific problems.
Hello.
Thank you a lot. It helped me a lot and my problem in solved.
Well i am a Mechanical Design Engineer, that is why i wrote this qurey in the AutoCAD Mechanical General Discussion. But i am not using Autocad Mechanical these days as i got innolved in the civil project to be completed and yes i do use Autocad Mechanical 2014.
Keep Smiling.
Have a nice day..
