Mid Between 2 Points Error (AutoCAD Mechanical 2022)
Rkuehne
Observer Observer
Rkuehne
Observer
Observer
After actively moving an object, if you right click to select the option to use "Mid Between 2 Points", AutoCAD glitches and no longer shows the curser and you can't complete the move.  This has never been an issue with 2021, so hopefully it can resolved with 2022 unless anyone has a workaround.  Thanks.
pendean
Community Legend
Community Legend
You will need to log into your Autodesk Account, start a support ticket, and report the issue.
All of us in here are end users just like you, Autodesk only comes in here to ensure we are all behaving, not much else.
a.zwegers
I'm experiencing the same issue
gaurav.satalkar
Apologies for the issue faced here. This is already logged in our system as a defect, and we are investigating it.
Thank you,
Gaurav Satalkar
QA Engineer
Hope you can fix it soon 😀
