I am using AutoCAD Mechanical 2015 - SP1 (64-bit) from Product Design Suite 2015 on Windows 8.1
When trying to initiate Viewbase command, it returns with the statement "Inventor server failed to load"
What is the fix for this issue?
Cheers
Solved by david.penney00. Go to Solution.
Hi David,
The problem may have different causes. Please check the followings:
Please check the above and let me know the results.
Thank you.
I uninstalled the suite and then reinstalled the suite with all hotfixes/service packs and this seems to have fixed the matter.
So all good.
Thanks for your attention.
Regards.
