How to show the properties pallet in the Ribbon ACAD Mechanical?
basmalli
Message 1 of 12
basmalli
I there any option to show the properties pallet in the toolbar as shown in the attached screen shot, so that we can avoid typing the command PR every time and this was there in AutoCAD Mechanical 2014 but i am not able to find in AutoCAD Mechanical 2017.
[The subject line of this post has been edited for clarity by cheryl.buck from: How to show the properties pallet in the Tab?]
Replies (11)
Message 2 of 12
cheryl.buck
Autodesk Support
Autodesk Support
Hi @basmalli,
That is a great question. The Properties Palette is an entity separate from the Ribbon, but it can be opened from the Ribbon under:
  1. The View tab, Palettes panel.
  2. From the pop out arrow on the Home tab, Properties.
See the screen shots below.
Properties in the Ribbon.JPGT
Please let me know if this answers your question or if you have further questions.
All the best,
If a post was helpful, Likes are always welcome.
Please select the big green Accept as Solution button on any post that answered your question or solved the problem.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 3 of 12
basmalli
Hi Cheryl Buck,
Thanks for the reply, but your suggestion has not led to the solution.
1. The first point is clear.
This is my requirement, but i could not find out Properties panel in my home tab as you have shown, attached is my screen shot of the home ribbon.
[This post has been edited for clarity by cheryl.buck]
Message 4 of 12
cheryl.buck
Autodesk Support
Autodesk Support
Hi @basmalli
I apologize, I believe I had the Vanilla profile open when I took the screen shot. It is possible to modify the CUI to include the Properties button on the Home tab of the Ribbon.  See the following Autodesk Knowledge Network (AKN) article for instructions:
To Customize the Ribbon
This video from Lynda.com also does a walk through:
How to customize AutoCAD Ribbon and Panels
The button is called Properties. Please let me know if this is helpful.
All the best,
Cheryl Buck
Message 5 of 12
cheryl.buck
Autodesk Support
Autodesk Support
Hi @basmalli.
I am checking back to see if my post helped you adding a Properties button to AutoCAD Mechanical 2017. I also added a video tutorial that I found on Lynda.com.
Please let me know if this helps resolve the issue or if you have additional questions.
All the best,
Cheryl Buck
Message 6 of 12
pendean
Community Legend
Community Legend
Quicker answer: no.
Any reason you don't either dock and auto-hide PROPERTIES on the side if you do not have a second monitor to place it there instead?
Message 7 of 12
basmalli
The video tutorial cleared all my doubts thanks Cheryl Buck...
Message 8 of 12
cheryl.buck
Autodesk Support
Autodesk Support
Hi @basmalli,
I am So glad to hear that the video helped. Thank you for posting and letting the community know.
All the best,
Cheryl Buck
Message 9 of 12
mrshayboo
I get to the part of being able to add in  a panel to the Home tab via the CUI however I can't find the Home-Properties panel within the list. I'm requiring the Properties Panel within the Home tab as it allows for changing the Linetype easily.
See a screenshot of part of the list below.
Message 10 of 12
pendean
Community Legend
Community Legend
If the panel is in the Ribbon and you can see/use it, then it is in the CUI too, so you either have the incorrect CUI selected before going into the panels section OR you decided not not scroll up/down that area you provided a screenshot for to look for it since it may not be perfectly in alphabetical order all the time for anyone anywhere, CUIx placement tends to be by edit
Message 11 of 12
mrshayboo
By "incorrect CUI " are you referring to the different workspaces? neither have the Home- Properties panel.
The issue is that I can't see that specific panel. I have looked through the whole list (see pic attached if you don't believe) and it doesn't contain that panel.
My AutoCAD Elec does contain that panel, Is there a way I can transfer that over?
I've tried copying the workspace from ACADE CUI and pasting it in ACADMECH CUI but that doesn't work.
Message 12 of 12
pendean
Community Legend
Community Legend
@mrshaybooIn your screenshot, you are running your older than 2023 ACADE "as AutoCAD".
The "correct CUI" for that panel you want would be this one (ACAD.CUIx)
When running ACADE as ELECTRICAL, the ACADE.CUIx does not contain the plain-AutoCAD panels, you have to select the ACAD.CUIx from the list first then you see the panel you want
MECHANICAL seems to not autoload ACAD.CUIx when run as MECH, at least not in my 2023
