How to disable F1 (Help Button) in AutoCAD
tj6TCQ5
tj6TCQ5
I found that these instructions do not work in my 2017 AutoCAD. For step 8 there is no lower line to enter anything. The only input available changes the F1 key into Shift+F1 without the option to edit it. If you try to edit it, it will clear itself and wait for another key command.
[This post has been split from the thread: Disabling "F1 key... "Help Button" in AutoCAD" and the subject line of this post has been edited for clarity by cheryl.buck]
pendean
Community Legend
Community Legend
Are you trying to edit a CUIx file (or Enterprise CUIx) you are locked out from?
tj6TCQ5
I'm sorry, my error was my own making. Where I work everything in CAD is done in caps and I didn't realize that would influence the input. It does say the lower line in step 8 which is not a good description of the key-shortcut input box that is available so I believed there was a difference in the prompt from the original post.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @tj6TCQ5,
I am checking back to see if switching from using capitals resolved the issue. Please take a moment to post an update letting the community know.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
tj6TCQ5
Yes, I was able to get this to work with the caps lock off.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @tj6TCQ5,
Excellent! Thank you for posting to let the community members know.
All the best,
Cheryl Buck
