i have a autocad Mechanical 2014. but express tool not available. how i install the express tools in to software?
BR
Chandana
BR
Chandana
Solved by Sridhar-Autodesk. Go to Solution.
Dear All,
i followed instruction according to post massges regarding to "express tools" topic . according to insturction i loaded cuiload & load express tool. then run appload & load Acettest.fas & Acetuil.fas. bothe are successfully loaded. but acad popup d.box as "anable to load acututil.arx" so how i fix it? please help me.
BR
Chadanana
Dear All,
BR
Chadanana
the express tools are commonly installed together with the rest of the installation.
I am not sure, but you could try starting up setup.exe again, get to the checkboxes and installing the express tools that way. Else you'll have to reinstall the complete package.
Hae, you can type CUILOAD in the commandline, check whether EXPRESS is in the list of the loaded customizations Suggestion
when you recover the settings, Use Autocad 360 to sync your settings that way you can recover the CUI settings by syncing back with Autocad 360.
It saves a lot.
It saves a lot.
Hi
Can you try the solution from the following link.
Once the express tools are loaded, please try below 2 steps
Step 1 >> CUILOAD the cui file “acetmain.cuix”>>Express Tool panel is listed in the ribbon
Step 2 >> APPLOAD 2 FAS files(acettest.fas and acetutil.fas) from the express menu,
Hi
Did the previous posting resolve your issue?
Jon.
Jon.
Now ok other express tools installing & those are successfully working but arctext command had doubt. the issue is every time need to appload command & load "ctextapp.arx" work with arctext command in every ACAD software loading so please help to fix this issue.
BR
Chandana
BR
Chandana
Chandana,
Can you try adding the ctextapp.arx to the startup suite and verify the issue.
Appload>>Contents>>Add>>ctextapp.arx
By following the above step, ctextapp.arx will be loaded automatically when AutoCAD launches.
Chandana,
Dear Sridhar,
it's works fine. thaks your valuble support.
BR
Chandana
Dear Sridhar,
BR
Chandana
