I have a drawing that every time I open it goes to drawing recovery and it passes with no errors. I purged all blocks and save but when I open the drawing again it starts in recovery and gives the message "Audit detected no errors in recovered database." and opens.
Does anyone know how to fix this?
Solved by tgg901. Go to Solution.
Block out the drawing and paste it into a "clean" drawing. Sometimes this just happens for no apparent reason.
Ok I found the issue. I have found these nodes (see attachment) on my drawing. It's named ACAD_PROXY_ENTITY ON LAYER AM_12.
I'm not sure where they came from but I erased them, saved the drawing and it reopens without the recovery process.
Problem fixed!
If anyone can tell me how these were inserted and what purpose they serve would help me in the future.
Thank you Steve for replying with your response but don't need to block out the drawing now.
These are entities created by either vertical versions of AutoCAD (like CIVIL or ARCHITECTURE etc.), or third-party add-ons. ACAD_PROXY_ENTITIES can also be objects that are normal autocad objects from a more current version that have no functionality in an older version. Example is say, multi-leaders. They would work in 2010(?) and up, but they are frozen proxy entities in an older version.
You can try running a recover. Just type in RECOVER in your command line, it will then ask you to select your file. If that does not work, in your open drawing dialog box, right click on your drawing name, select the properties option, then select the previous options tab. There should be a few versions, highlight the one you want and select the view button, it might take a minute, but a dialog box will show up saying it is a read-only drawing. Select ok, and it will open up the drawing and if it is what you want you can do a save as and overwrite the corrupt file.
I was getting a request to recover every time I opened some drawings. Mainly from one contractor. When recovered however, no faults were found and it would do the same thing the next time I opened the drawing. this is in autocad mechanical 2016.
I found that if I saved the drawing to a 2007 version drawing, purged it, then it would open without the recovery request. I then purged the drawing once opened again a heap of extra stuff was purged out of the drawing.
Hope this helps someone
