Drawing Nut and Bolt
Message 1 of 8
In this YouTube tutorial author is converted surface into solid when drawing Bolt.
I wish to know why first author creates a surface model then converted into solid model in making BOLT, instead of straight away going to solid model.
Following is the link.
https://www.youtube.com/watch?v=5Q1s_VlaKTI
Replies (7)
Message 2 of 8
JDMather
I didn't watch the video - but my guess is simply that they don't know how to use AutoCAD.
Message 3 of 8
I ask author he gave me answer, but I couldn’t understand it. See whether you can understand it. Screenshot is attached.
Message 4 of 8
Frequently new features are added to improve the AutoCAD drawing. Please see whether which one is more accurate in making NUT and BOLT (Tutorial 4 Threads or YouTube one). Your help is important to me.
Message 5 of 8
JDMather
@Anonymous wrote:
Frequently new features are added to improve the AutoCAD drawing. ....
I no longer use AutoCAD for mechanical design (3D).
I recommend that you invest your time in learing Autodesk Inventor or Autodesk Fusion 360.
Message 6 of 8
What is the different between Autodesk Inventor and SolidWorks.
Message 7 of 8
JDMather
Same as Ford and Chevrolet (or whatever car manufacturers are in your country).
Essentially no difference - just different companies.  If you can drive one - you should be able to drive the other.
Message 8 of 8
Thank you for your explanation.
From next week my college begins to teach Autodesk Inventor.
In job ads some companies ask for Autodesk Inventor and other companies ask for SolidWorks. I wish to know if I learn Autodesk Inventor whether it is possible to apply for jobs requesting knowledge of SolidWorks as well.
