AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
dialouge box is not opening
2 REPLIES 2
482 Views, 2 Replies
Dear all,
I am using Autodesk Mechanical 2011,
when ever I am press the open/save/save as button the dialouge box is not opening see the attached photos for what coming after i press the buttons,
I alredy repaied the autodesk mechanical but nothing is changed , I still having same problem,
If any one having solution than help me,
Walekar Dattatraya.
2 REPLIES 2
RogerMollon
On the command line type "FILEDIA" (without the quotes), then <enter>, at the pompt type "1" (without the quotes), then <enter>.  Do the same with "CMDDIA".  For some reason one or both of these SYSVARS got set to "0" (zero).
I hope this helps,
Roger Mollon
Forge - Strategic Tech Consultant - Novi
Autodesk, Inc. - Retired
in reply to: RogerMollon
u r solution works well.
Thanks & Regards,
Walekar Dattatraya.
Technology Administrators
AutoCAD Beta
