Data Extraction to excel
frj
Observer Observer
frj
Observer
Observer
Hi
Background:
I am working on creating a parts-library, i am doing this by creating blocks from exsististing parts such as different pumps, valves or similar.
If these blocks are properly defined i should then be able to add them a drawing/an arrangement of these parts and then extract details, such as locations for each part.
I can do this by using the command "Dataextraction".
Iam working with autocad 2016.
Problem:
I have noticed that you can add attributes to the blocks and i cant seem to figure out how to extract this data to excel.
I have added an attribute called "weight" and given it a specific value and i would basically like to extract this "weight"-value and the location of the part to excel.
My dream is to make a smart button using VBA - which add/change weights and locations on objects depending on my autocad drawing.
Am i using to wrong command or do any of you have a smarter approach for this?
Thank you.
maximilian.kroner
Hi @frj,
there is a tutorial over at the Civil Immersion that I believe explains what you are trying to do. It is for Civil 3D but maybe it works for mechanical as well:
Finish Strong Friday: Civil 3D Property Set Data – Link to Excel with Fields
MaximilianKroner
Technical Support Specialist
