When I copy a drawing and it's dimensions onto my clipboard, and paste it into another drawing, a lot of times all the dimensions will change and come out way too big or way too small. This is because our drawings have all different dimstyle values for the same dimension styles. The overall scale factors on the styles are often way off from each other.
Is there a way I can make it so that when I copy dimensions to my clipboard and paste them in another drawing, they retain all their own individual properties instead of morphing to the new drawing's dimstyle settings?
@RIPBillyMays
Topic Title has been changed for better findability by @joaquim.moral Original Post:
Solved by pendean. Go to Solution.
Hi @RIPBillyMays,
Thank you for posting in the AutoCAD Forum! I'm checking in to see if you need more help with this. Did the suggestion that @pendean provided help you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily. If not, let us know if you have any more questions so we can help you.
Best,
Joaquim
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Your question got successfully answered? Then just click on the 'Mark as solution'
Joaquim Moral
Spanish Community
