Content library
Content library
peterm
Message 1 of 19
Content library
peterm
Is there a content library for standard parts and features in AutoCAD Mechanical 2022?
If so, how do I access it?
Replies (18)
Message 2 of 19
rdaveyCCXBN
check in content manger see if this is what you are asking for
Message 3 of 19
peterm
Where do I find content manager?
Message 4 of 19
rdaveyCCXBN
content on ribbon tab
Message 5 of 19
peterm
I don't use the ribbon.
However, when I type in CONTENT at the command prompt, the DesignCentre pops up.
Under en-us dynamic blocks there are just 4 types of metric nut and bolt.
Message 6 of 19
rdaveyCCXBN
try AMcontentmanger in command line
Message 7 of 19
peterm
Comes up as unknown command.
Message 8 of 19
rdaveyCCXBN
AMCONTENTLIB see if this helps I am using 2020 right now.
Message 9 of 19
peterm
Unknown command again.
I'm using AutoCAD Mechanical 2022.
Message 10 of 19
gaurav.satalkar
The commands to be used are AMCONTENTMANAGER and AMCONTENTLIB. If it shows Unknown command, it is very likely that you are using the AutoCAD Profile.
From the start menu, you can start the "AutoCAD Mechanical 2022" instead of "AutoCAD 2022".
There you will be able to see all the Content for Mechanical Standards.
Hope this helps.
Gaurav Satalkar
QA Engineer
Message 11 of 19
peterm
Hi Gaurav. I am launching Mechanical 2022.
I think something must have got lost when I migrated my settings from a previous version.
Message 12 of 19
gaurav.satalkar
Ok. Did you try to reset the settings to default? You can also backup the settings when performing a Reset.
If done already, Did it work after that?
Gaurav Satalkar
QA Engineer
Message 13 of 19
peterm
I don't particularly want to reset the settings to default as it takes a while to get the custom add-on software up and running. I may give it a go when I have some quiet time, or maybe just leave it alone as it's not affecting my productivity in anyway.
Message 14 of 19
steve-NEO
Check OPTIONS then goto profile. What are you using? Mine has 2.... ACADMPP and VANILLA.... mine is set to the 1st. Hope that helps.
Message 15 of 19
peterm
Hi Steve. Thanks for the suggestion.
Mine is also set to ACADMPP, so it's not that.
Message 16 of 19
m_latz
If I have understood correctly, you have imported your modified "ACADMPP" profile from an older version of AutoCAD Mechanical to AutoCAD Mechanical 2022 ?
To check if your AutoCAD Mechanical 2022 is correctly installed and only your imported profile makes trouble, I can send you a "renamed" ACADMPP.arg file. Then you can use this to test if everything is working.
Should we try this ?
regards
Markus
Message 17 of 19
peterm
Hi Markus,
It's certainly worth a go. Thanks.
Message 18 of 19
m_latz
Okay, here a renamed original ACADMPP profile from AutoCAD Mechanical 2022 English.
Just unzip, store on your local hard drive, copy an existing AutoCAD Mechanical shortcut and modify:
"C:\Program Files\Autodesk\AutoCAD 2022\acad.exe" /p "C:\Temp\AcadMPP-AcadM2022-Enu.arg" /product ACADM /language "en-US"
It is important, that you start AutoCAD Mechanical with this profile. It is not the same if you start AutoCAD with another profile and switch the profile in AutoCAD !
regards
Markus
Message 19 of 19
peterm
That works. So there must be something wrong with my ACADMPP file.
I'll look into it.
Thanks for your help.
