command database doesn't show stiffener
hello. i'm trying to build stiffeners, googled and found out it's accessible through the command Database -> Fittings -> Stiffeners. tried the command but what showed up was AMBOM instead, used for Billing of Materials. what do i do?
Sridhar-Autodesk
Hi
Can you use command amstlshap2d in AutoCAD Mechanical and verify if that helps.
OR AutoCAD Mechanical>>Ribbon>>Content Tab>>Parts Panel.
Sridhar Subramani
Senior Product Owner
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD Mechanical forum. Welcome to the Autodesk Community!
I am checking back to see if the information provided by @Sridhar-Autodesk helped resolve the issue or answered your question. Please post an update letting the community know.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
