Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Cannot Export STEP file
Message 1 of 10
Hello, I cannot export an autoCad .dwg file into a step file. I tried with the STEPOUT command on the command window.
Is this even possible with an educational version of AutoCad?
Thanks for your answers, Ingmari
Replies (9)
Message 2 of 10
Rob67ert
Does the stepout command work at all or does it give; command unknown?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 3 of 10
It says "Unknown command", so my guess it the command is missing in the educational version.
Message 4 of 10
Rob67ert
It should be also in the educational version.
Are you working with AutoCAD or with AutoCAD Mechanical?
It is only available in Mechanical.
Look in options under profile, if Vanilla is active you are on plain AutoCAD.
Robert
Message 5 of 10
Yes, this was the problem. Thanks for pointing it out!
Message 6 of 10
corey_adams
Hello I have a drawing that use to be a a STEP file, it was "BURST" into individual 3d parts is there a command to re-combine the parts so I can perform  "STEPOUT"  I tried "SURFSCULPT" I am working in Mechanical Cad.
Thanks.
Message 7 of 10
rwinokur
I am using Mechanical 2021 and not in Vanilla profile and STEPOUT still reports unknown command
Message 8 of 10
AIR_123
Can you please explain in details how to fix STEPOUT "unknown command". In 2021 its not working for me even if ACADMPP is selected in profiles. Thanks
Message 9 of 10
AIR_123
Found solution for my issue. After resetting the ACADM to defaults, export to STEP is working now. Probably has something to do with profile import from previous version, or maybe I've imported vanilla ACAD profile into mechanical which is potentially screw up CUI paths...
Message 10 of 10
Lee_DaviesL4UCV
Observer
Observer
Doing this solved a lot of issues for me.
Fixed the problem.
