cannot convert a POLYLINE to a LWPOLYLINE
KevinMacDonald
KevinMacDonald
This is such an old and tired subject with a billion answers on the forums. And yet, nothing works for me.
The attached file contains a single POLYLINE. I would like to convert it to a LWPOLYLINE, so that I can then use the wonderful PLDiet.lsp routine on it to reduce the number of points.
CONVERT will not convert it.
CONVERTPOLY will not convert it.
Ideally, I would like to be able to convert ALL POLYLINE objects in one go to LWPOLYLINE objects.
Can anyone provide precise instructions?
Inventor 2013
KevinMacDonald
I have also tried FLATTEN. If I indicate YES to the "Remove Hidden Lines" option it does in fact turn a POLYLINE into a LWPOLYINE. But, it takes what was a nice smooth POLYLINE and turns it into jagged LWPOLYLINE. I need to be able to preserve the appearance.
Inventor 2013
Patchy
x
devitg
@KevinMacDonald Hi , the main fact is that it is a "AcDb3dPolyline" whose  Z value are not constant to any value.
do you want to be all Z to  0 (zero)??
KevinMacDonald
My reason for wanting to get away from polyline is because it is
problematic extruding them into 3D objects. A 'Closed' LWPOLYINE is
generally what I need. Sometimes FLATTEN or FLATSHOT get me to where I
need, but not consistently. I'm often importing art work from Illustrator
and it is kind of a garbage clean up process. A lot of times Illustrator
will give me Splines, and the PEDIT command converts those to polyline not
LWPOLYINE.
Inventor 2013
devitg
@KevinMacDonald
Hi , please check it .
devitg
@KevinMacDonald How about it ?
