Can't move, rotate, edit text, change dimensions
Message 1 of 1
I was working in a drawing for a while and all of a sudden several functions are not working.
I can't double click on text to edit it.
I can't move an object by selecting move from the drop down menu
I try to rotate an object by selecting rotate from the drop down menu.  Then when I select the base point to rotate, it deletes the object.
I can't drag any point on an object to change it's length or position
Any advice would be greatly appreciated!
Replies (0)
