Can't insert a leader note in AutoCAD Mechanical 2016 Drawing
jweiss1313
jweiss1313
I have a drawing that I am unable to insert a leader and text in.  Some times when I select an object I get an animation of a mouse with a blinking red left button and a steady green right button with a rotation blue arrow.  I don't know if the two are related or not.  I'm able to type the "LEADER" command and place a leader with not issues.  Its only when I select the Leader Note button on the Symbol ribbon panel.  If I open a new template file, the command works fine.  It apparently something with the drawing.  I've attached a copy of the drawing.
We are an Inventor house, but we have a few factory layouts that are in AutoCAD and nobody seems to know what is going on with this file.  Any help would be appreciated!
Thanks!
Dell Precision T7500
Windows 7 x64
16 GB RAM
Quadro 5000 Graphics Card
Autodesk PDSU 2016
AutoCAD Mechanical 2016 SP1
John C Weiss Jr.
CAD Manager
Follett LLC.
steve216586
If you are only having trouble with this one file, it sounds like it may be corrupt.
1. Try RECOVER
2. Copy all and paste in another blank drawing.
3. DXFout - then in new blank drawing - DXFin
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
jweiss1313
Hi Steve,
Tried everything you suggested and still have the same problem.  Have you ever seen the mouse animation shown in the attached screen capture before?  Do you know what it means?  I have a feeling it is trying to tell me something related to why I can't use the leader note command.
John C Weiss Jr.
CAD Manager
Follett LLC.
Yong.Jing
Autodesk Support
Autodesk Support
Dear John C Weiss Jr.,
You have froze and thrawn AM_5 layer, so all dimension and annotation is unable to be viewed. Please turn this layer on, it could be seen.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
jweiss1313
Thank you very much for your help that was the problem.  Before I accept your post as the solution, I like to know what the mouse animation is supposed to tell me.  Sometimes when selecting an object to apply a leader note I get a mouse animation attached to my curser.  The left mouse button is blinking red and the right button is green and there is a blue arrow that rotates around the mouse.  Please tell me what it means.  Thanks!
John C Weiss Jr.
CAD Manager
Follett LLC.
Yong.Jing
Autodesk Support
Autodesk Support
Thank you for choosing Autodesk . It's pleasure to know that issue has been solve at your site.
About the blue arrow that rotated around the mouse,if the mouse activities has options in the next step, it will pop up these options to choose. Different function has different rollover tooltips. From my experience, i like to view the UI dialog box and command line too. In this way, it will guide me what's the meaning of the symbol.
Yong Jing
jweiss1313
Thank you so much for all your help!  I really appreciate it!
John C Weiss Jr.
CAD Manager
Follett LLC.
