I am trying to create a hole chart for one of the jobs I am working on. My drawing view scale is 1/4. The problem I have is that the hole diameters and XY coordinates do not scale x4 to compensate for the drawing view scale when creating a hole chart. This results in an incorrect hole chart. For example, 1.00 dia. hole at (4,4) comes as .25 dia. hole at (1,1). Is there any way to change the scale of the hole chart?
Hi @aatishparmar,
Thank you for posting your question. Only annotation objects that are set to annotative for the view scale will adjust in size.
If you would like to share your file, we would be happy to take a look.
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
I do not have an issue with the size of the object. What I am looking for is the value of the dimension being scaled to the view. I can do that by changing the dimscale. However, I do not have that option for the hole chart. So I am looking for a method to change the values of hole locations in the hole chart according to the drawing view scale. Look at the attached picture. 2.000 dia. hole is located at 12" from the edge. But hole chart shows it at 3". Does anyone know if we can add a scale factor to a hole chart?
Thank you.
