Blocks with Part refernce
mathew.joseph
mathew.joseph
I have a few blocks with part reference attached. when I am using it as symbols for a process flow diagram, I need to tag them with different id's.
But blocks with Part reference gives the same tad number with quantity added up in BOM.
I want them with different Tag Ids and no addition of quantity.
Is it possible to do that for such blocks?
Mathew
Sridhar-Autodesk
Hi
For such cases, you may need to create another block with no Part reference info and attribute.  The ID will be your attribute when you insert the block.
Use command ATTDEF to define an attribute before creating a block.
Hope this helps.
Sridhar Subramani
Senior Product Owner
cheryl.buck
Autodesk Support
Autodesk Support
Hi @mathew.joseph,
I am checking back to see if the information provided by @Sridhar-Autodesk helped answer your question.
If the post was helpful, Likes are always welcome.
Please click the Accept Solution button if it resolved the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
