We are developing an AutoCAD plugin which automatically generates drawings for a set of inputs. These drawings contain dynamic blocks which can be manipulated with dynamic properties. When we manipulate the dynamic blocks the dimension objects also get updated automatically except the tolerance deviation values. It has been encountered that the values of deviations gets updated in the fits menu, but are not reflected in the modelspace unless we open the fits menu and press OK (i.e., Select dimension > Fit/Tolerance tab > Fit symbol dropdown > Fit dialog box).
We've already tried different commands like DIMREGEN, REGEN, etc. But still unable to get those values updated. Is there something we're missing or is there any workaround for this issue?
I've attached a screenshot for your reference. Thanks in advance.
