AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
AutoCAD Window Minimizes
9 REPLIES 9
Message 1 of 10
BCrosby
5947 Views, 9 Replies
BCrosby
I have been experiencing a problem with my AutoCAD window minimizing when I switch between drawings or switch to other programs. The minimizing that I have been experiencing is the window shrinking about ½” all the way around my screen, not minimizing to the taskbar.
The only fix I have found for this is to change the “TASKBAR” value from “1” to “0”. This resolves the minimizing issue but all my open drawings are now displayed on tabs up above my drawing window instead of down on the taskbar where I prefer.
Any other suggestions to fix this issue?
Bruce M. Crosby
Broomfield
Engineering Department
GIGABYTE Z490 Vision D (Intel LGA1200/Z490/ATX/3xM.2/Dual Thunderbolt 3/SATA 6Gb/s/USB 3.2 Gen 2/Intel WiFi 6/Direct 12 Phase Digital Power/Intel 2.5G LAN/Motherboard)
Intel Core i7-10700K
Samsung (MZ-V7E1T0BW) 970 EVO SSD 1TB - M.2 NVMePNY Quadro P5000 VCQP5000-PB 16GB
Crucial Ballistix 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 128GB 32GBx4
Dell Ultrasharp U4919DW Curved 32:9 49” Display
Windows 10 Professional 64 Bit
CAT 7 Ethernet
HP Designjet T3500
3D Connexion SpaceMouse Enterprise
3D Connexion CadMouse
Autodesk Vault Basic 2020
Autodesk Inventor Professional 2020
Autodesk AutoCAD Mechanical 2020
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
9 REPLIES 9
Message 2 of 10
bryce.thelin
in reply to: BCrosby
bryce.thelin
Hi Bruce,
What might be doing it is Aero effects in Windows 7. Try setting your desktop theme to Windows 7 Basic. Do you maybe have a theme utility of some kind installed? I could see something like that interrupting the display of programs when you ALT-Tab between them.
Check the Aero snap feature in Windows (although, changing to the Basic theme probably disables this):
http://www.pcworld.com/article/220222/Windows.html
Bryce Thelin
AutoCAD Product Support
Hi Bruce,
Bryce Thelin
Message 3 of 10
BCrosby
in reply to: bryce.thelin
BCrosby
Yes, switching the aero theme to basic definetly effects it. Sounds like a work around to a bug to me, not a fix. Changing the taskbar setting to '0" was another work around but not a fix.
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Message 4 of 10
bryce.thelin
bryce.thelin
How about just turning off the Aero Snap feature?
Bryce Thelin
Bryce Thelin
Message 5 of 10
BCrosby
BCrosby
The only way around this issue is to set the Taskbar value to "0". I've tried your suggestions without sucsess.
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Message 6 of 10
bryce.thelin
bryce.thelin
I cannot seem to recreate the problem on my own computer, so this may be something unique to your system and not necessarily a bug in AutoCAD (although I cannot rule that out completely). I haven't been able to find any other reports on this from other customers though.
Unless living with the TASKBAR variable set to zero is okay, go ahead and try resetting AutoCAD to defaults and if that doesn't help, try uninstalling and reinstalling it. If reinstalling doesn't fix it, then I would suggest removing and reinstalling the .NET Framework and Visual C++. .NET especially governs most of how AutoCAD displays its windows. Here are a couple articles on reinstalling .NET and C++:
http://knowledge.autodesk.com/article/How-to-remove-and-reinstall-the-Microsoft-NET-Framework
http://knowledge.autodesk.com/article/How-to-remove-and-reinstall-Microsoft-Visual-C-Runtime-Librari...
Bryce Thelin
Bryce Thelin
Message 7 of 10
bryce.thelin
bryce.thelin
Hi Bruce,
I wanted to check in with you to see if you figured out what the problem was or if you were able to fix it, or if you decided to just stick with having TASBAR set to zero.
Bryce Thelin
Hi Bruce,
Bryce Thelin
Message 8 of 10
BCrosby
BCrosby
I tried a few different things that were suggested but I think I am going to stick with the TASKBAR setting option. I don't really like it but it is the easiest change to deal with.
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Message 9 of 10
I just wanted to say thanks to the OP for mentioning the variable. This is an extremely annoying behavior because it happens ALL THE TIME when switching windows.
Just to make it clear this is still a WORKAROUND.
Message 10 of 10
joshfKDSWP
joshfKDSWP
Thank you! Setting taskbar to 0 is a nice workaround.
