AutoCAD Mechanical 2015 - Add to group function
Hi there,
I have an error in AutoCAD Mechanical 2015 when using the "add to group" function. I go through all the steps, select "edit group", "add to group", select the group I want to manipulate, select the piece I want to add and press enter. All the steps seem to work fine except the final one, when I press "enter". It doesn't seem to do anything except cancel the group editing and and stay on the last piece i selected, which is the one I wanted to add, but it did not add.
I have restored default settings, uninstalled/reinstalled, and even installed on another computer where the error replicated itself even though I did not make any changes to the application.
Any help is appreciated!
matthew.d
Hi @Anonymous,
Welcome to the community.
Have you tried update AutoCAD Mechanical's service pack?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
