ARRAY ribbon button does not show preview
mauro.lepore
Observer Observer
mauro.lepore
Observer
Observer
sorry for my bad english.
I have a problem with array's command in Mechanical 2016.
I select the command from toolsbar then I select object to multiply. In the past a preview of the array was displayed but now no.
If I drag a grip (mouse click),  the preview work but after my confirmation (click) the preview disappear. At the end when I confirm varius options, array don't appear and autocad delete also first object selected.
if I cancel the command, the initial object is also deleted.
If I switch in Autocad "Structure" instead "Mechanical" and use array classical, that work well.
I tried to re-install Autocad but nothing changed.
Suggestions?
Thanks in advance.
[The subject line of this post has been edited for clarity by cheryl.buck from: Array don't work]
cheryl.buck
Autodesk Support
Autodesk Support
Hello @mauro.lepore,
I see that you are visiting as a new member to the AutoCAD Mechanical forum. Welcome to the Autodesk Community!
You did a great job of describing your issue! I believe two buttons you are using in the Mechanical workspace Ribbon and the Structure workspace Ribbon are different even though the icons are the same.
If you hover over the command in the Mechanical workspace Ribbon (or click the drop down next to it) you will see the button initiates 1 of 3 different Array commands. If you simply click on the button, most likely the command is ARRAYRECT, while in the Structure workspace the button is only for the ARRAYCLASSIC command.
While ARRAYCLASSIC is not in the Mechanical Ribbon as installed, it can be added. See the following Autodesk Knowledge Network (AKN) article:
Adding new toolbar buttons | AutoCAD
The path for the Array drop down in the Mechanical Ribbon is Ribbons > Panels > Home Modify > Row 1 Sub-Panel 3 > Row 1 > Array
Please let me know if this helps.
All the best,
If my post was helpful, Kudos are always welcome.
And if it answered your question or solved your problem, please select the Accept as Solution button.
[This post has been edited for clarity by cheryl.buck]
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @mauro.lepore,
I am checking back to see if my post helped you with your problem.
All the best,
Cheryl Buck
