- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
sorry for my bad english.
I have a problem with array's command in Mechanical 2016.
I select the command from toolsbar then I select object to multiply. In the past a preview of the array was displayed but now no.
If I drag a grip (mouse click), the preview work but after my confirmation (click) the preview disappear. At the end when I confirm varius options, array don't appear and autocad delete also first object selected.
if I cancel the command, the initial object is also deleted.
If I switch in Autocad "Structure" instead "Mechanical" and use array classical, that work well.
I tried to re-install Autocad but nothing changed.
Suggestions?
Thanks in advance.
[The subject line of this post has been edited for clarity by cheryl.buck from: Array don't work]
