creating a map with differend styles without using the automatic theme take much time!
It would be so helpful to export once created styles to a file like ESRI *.lyr, and import it to new FDO Data to use it again.
I know the using of *.layer files, but they only work with the same FDO file to transport them from one map to an other map. That is helpful, but every time the name of the file changed, p.e. update of Data, you start again. Or am I wrong and did't find the way?
