MAP New features - 01 - Improvments on Object Data
Subject: MAP New features - 01 - Improvments on Object Data
Hello
So after my very long wish list :
http://forums.autodesk.com/t5/autocad-map-3d-general/map-3d-2016-quot-new-features-quot/td-p/5573909
and especially my message : 04-10-2015 10:51 PM in reply to: gluckett
And don't forget the answering message of albert : kalman.albert - 04-11-2015 03:44 AM in reply to: braudpat
I will propose new features for ACAD MAP in each category !
****** Must have : Improvments for ODs ******
01) --- Object Data General and EDIT ---
010) Remove the stupid length limit of 131/132 chars for "String OD Field"
PLEASE increase this LENGTH LIMIT to 254/255 chars ...
01A - Be able to rename an OD field/column
01B - Be able to reorganize the order of fields/columns (up/down)
01C - Please a function like Search and Replace ODs
01D - Add Prefix or Suffix on alphanumeric ODs
01E - Add or Multiply by a value for numeric ODs
02) --- Object Data - Select, Query, Update, etc --- in the CURRENT drawing ---
Be able to see OD as a Grid (idem the Attributes Tables with FDO)
Select, Query, Update, Export as CSV, etc
With options : auto-select, auto-zoom, etc
Regards, Patrice (I am not an Autodesk Advisor)
4 Comments
I completely agree.
But from Object Data, can get a lot more use.
Longtime supporters from India:
http://www.4d-technologies.com/techcenter/index.htm
http://www.4d-technologies.com/geotools/manual/autodesk_map_tools.htm
"But from Object Data, can get a lot more use." - http://adndevblog.typepad.com/infrastructure/2015/08/object-data-in-autocad-map-3d-as-the-simplest-a...
Posted as "idea".
berson.guillaume
I totally agree, it would help a lot. OD are useful but they could be way better !!!
I implemented all these tasks in my plugin. Most of these commands are now available - see the latest posts in the topic https://forums.autodesk.com/t5/autocad-map-3d-forum/additions-for-object-data/td-p/7548282
But it would be better if Autodesk himself did it!
