Zoom Extents different for 2015
aconstantine
aconstantine
We have drawings which were created in 2014 and when zoomed to extents they worked perfect.
When we open them in 2015 and do a zoom extents the drawing is not zoomed correctly. This happens on the simplist of drawings (please see attached drawing).
I have run though all ideas on this forum like ATTDISP, Erase all then remove by window, QTEXT etc. but non correct the issue.
Its strange that it only happens in 2015 products not 2014! Any pointers?
Cheers,
Adam
Alfred.NESWADBA
welcome @forums.autodesk.com!
I don't have a solution, just an additional info: erasing the hatches makes the ZOOM command in the layout working as expected.
The hatches are created based on a lot of SPLINE-objects, even straight lines as part of the characters in the logo are splines, that is unnecessary complex and makes the regeneration of the hatches slower. And I guess that might be the source of the problem (or at least part of it).
I would make the geometry simplier, combine the logo's to blocks and insert the finished block into your layouts.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
aconstantine
Hi Alfred,
Thanks for your welcome message and advise in solving my issue.
I will make the logo's simpler as deleting them allows my zoom extents to work correctly. Funny how it only happens in 2015 product releases.
Adam
