Please Help me to convert attached file to Obectdata or shape
Solved by CADaSchtroumpf. Go to Solution.
I tried. Your file crashed AD Map3d 2018 latest update for some reason. AEC objects maybe?
Opened in Vanilla CAD and copy and pasted in to Map3D and saved XDATA_2.dwg
There is no data on the objects that showed up so not sure of what you are looking for.
I sent all the data to a sdf file and selected properties that are in the data table.
Send more detail of what program and version you are using, and what data you expect to attach.
dave
Your file crash also my autocadmap 2014.
I have insert the file in explode mode in new drawing for can openned it.
Then i can apply this (copy-paste in command line) for transfert xdata to Object Data.
NB: Can be long, Autocad seem no respond but it make the job: Don't killing it
((lambda ( / js count n target_obj elist xd_list tbl fldnamelist fldtypelist e_data lst_tbl pos) (setq js (ssget '((-3 ("*")))) count 0 lst_tbl nil) (cond (js (repeat (setq n (sslength js)) (setq target_obj (ssname js (setq n (1- n))) elist (entget target_obj (list "*")) xd_list (cdr (assoc -3 elist)) tbl "XD_to_OD" fldnamelist (mapcar 'car xd_list) fldtypelist (mapcar 'caadr xd_list) e_data (mapcar 'cdadr xd_list) ) (if (null (ade_odtabledefn tbl)) (progn (setq lst_tbl (cons (cons tbl (list fldnamelist)) lst_tbl)) (ade_oddefinetab (list (cons "Tablename" tbl) (cons "TableDesc" "") (append '("Columns") (mapcar '(lambda (x y / ) (list (cons "ColName" x) (cons "ColDesc" "") (cons "ColType" (cond ((eq y 1040) "Real") ((eq y 1070) "Integer") ((eq y 1010) "Point") ((eq y 1000) "Character") ) ) (cons "DefaultVal" (cond ((eq y 1040) 0.0) ((eq y 1070) 0) ((eq y 1010) '(0.0 0.0 0.0)) ((eq y 1000) "") ) ) ) ) fldnamelist fldtypelist ) ) ) ) ) (progn (if (not (equal fldnamelist (car (mapcar 'cadr lst_tbl)))) (setq lst_tbl (cons (cons (strcat tbl (itoa (setq count (1+ count)))) (list fldnamelist)) lst_tbl)) ) (if (numberp (setq pos (vl-position T (mapcar '(lambda (x) (equal (mapcar 'cdar (cdaddr (ade_odtabledefn tbl))) x)) (mapcar 'cadr (reverse lst_tbl)))))) (if (null (ade_odtabledefn (setq tbl (car (nth pos lst_tbl))))) (ade_oddefinetab (list (cons "Tablename" tbl) (cons "TableDesc" "") (append '("Columns") (mapcar '(lambda (x y / ) (list (cons "ColName" x) (cons "ColDesc" "") (cons "ColType" (cond ((eq y 1040) "Real") ((eq y 1070) "Integer") ((eq y 1010) "Point") ((eq y 1000) "Character") ) ) (cons "DefaultVal" (cond ((eq y 1040) 0.0) ((eq y 1070) 0) ((eq y 1010) '(0.0 0.0 0.0)) ((eq y 1000) "") ) ) ) ) fldnamelist fldtypelist ) ) ) ) ) ) ) ) (ade_odaddrecord target_obj tbl) (mapcar '(lambda (x y) (ade_odsetfield target_obj tbl x 0 y)) fldnamelist e_data ) ) ) ) (prin1) ))
