AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Water: "Element already added. Key in Dictionary: ID_WATER_Quality"
4 REPLIES 4
Peter2_1
387 Views, 4 Replies
Always when opening a "water"-model I get the attached information-dialogue.
Translated:
Information
The element was already added.
Key in Dictionary: "ID_WATER_QUALITY".
Key to be added: "ID_WATER_QUALITY"
Where does it come from? How to fix it?
AutoCAD Map 3D 2023 German / Oracle
4 REPLIES 4
Koesti
in reply to: Peter2_1
Hi @Peter2_1,
I know ID_Water_Quality only from Industry Model Water where it is coming from Domain Table WA_Water_Quality_TBD.
The domain table in general is joined to the pipe table - are you working with predefined Industry Models based on DWG or Oracle?
If yes, can you please share some more details for example when the message comes - with opening DWG in Administrator or Map 3D.
Regards
Brigitte Koesterke
Technical Support Senior Specialist
Peter2_1
in reply to: Koesti
Brigitte,
sorry for being that imprecise.
Usage of Map 3D 2018 with Oracle
It happens in two (similar) ways.
a)
start map 3D - new drawing - open an enterprise project (with "water") - explorer appears - go to datamodel - entry "Pipe" - doubleclick on "Pipe" - message appears - confirm message with OK - everything seem to be OK, no more messages until project and drawing is closed and newly loaded
b)
start infrastructure admin - open an enterprise project (with "water") - explorer appears - go to Formular designer - entry "Pipe" - select "Pipe form" - press "preview" - message appears - confirm message with OK - everything seem to be OK, no more messages until project and drawing is closed and newly loaded
I looked at the water_quality-table; it seem to be OK.
The 1-click-check does not solve the problem.
Have a fine weekend!
Thomas_Stuehle
Hello Peter @Peter2_1,
does it make a difference on your side when you remove the field (shown in the screenshot below), save the form and add it new to the form?
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Peter2_1
in reply to: Thomas_Stuehle
Short answer: no difference
Long answer:
- I open Admin and remove the field.
- Save, close admin and close Map
- Open Admin - 1-click-maintainance - many fixes
- Close admin
- open admin - open form without the field!! - error message
- add the field again
- close and reopen - error message
