I believe they offer a "Getting Started Guide" that's either included in the physical package or is something you send away for. Autodesk has moved to the Help file as the main source of user info, rather than the guide, and as far as I know, they don't print user guides anymore. This may sound bad, but that Help file is probably the most thorough around.
Andrew Schroeder
Charone Concepts Ltd.
712-402 West Pender St.
Vancouver, BC, V6B 1T6
Tel: (604) 628-8858
Fax: (604) 628-8851
Email: aschroeder@charone.ca
Website: www.charone.ca
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
