Unique symbols assigned to points
Message 1 of 12
I'm looking for a method for where I can assign a specific custom symbol to a number of imported points and only those points.  As well as doing similar to multiple sets of points with varying custom symbols.   Anyone have any suggestions?
Thanks^^
Replies (11)
Message 2 of 12
parkr4st
what is available for attributes of the points in what file format?
dave
Message 3 of 12
АлексЮстасу
Yes, we need to know for which format.
If dwg, then it's easier to lisp. For example:
FRTO.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 4 of 12
definitely dwg, 2D, the symbol itself can be whatever it needs to be.  Normally i just draw it manually and copy and past it around.    the points are just standard GIS stations that were extracted from a db via shape and imported into cad.
Message 5 of 12
parkr4st
do the points have attached attributes, such as OBJECT DATA, identifying which symbol goes to which points?
Message 6 of 12
most definitely, nothing i see that represents image.  I can adjust my points via ddptype but that does them all and with a limited symbol.
Message 7 of 12
parkr4st
if you can post the data it would be most helpful
Use QSELECT to select the layer with points, copy and paste that data into a new dwg, save the dwg and post it.
dave
Message 8 of 12
АлексЮстасу
...FRTO why you don't like it...
You write what the replacement criteria points. On the basis of data obtained from the import? Then it is better to import Object Data.
Import points as blocks, join them in a Object Data with the right information.
Tools Map to display the points in the desired blocks: MAPWSPACE -- Task pane -- Display manager --...
Message 9 of 12
I think that was what i was trying to do but i got lost along the way.
I appreciate all the help 😄
Message 10 of 12
Pointdump
Vicky,
I think Alexander is on to something. You can also <<<Replace Survey Points With Blocks>>>. Kinda depends on the Format of your Data.(Shapefile, XML, ASCII, DXF, CSV....)
Dave S
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 11 of 12
O_Eckmann
here a screencast to show how you could use Object Data to add info on blocks and use this info to create a thematic analysis to change block display.
Olivier
Olivier Eckmann
Message 12 of 12
Awesome, it took me awhile, (i work 7 days/week in oil and gas) This was a huge area that added much to my mapping tools. thanks a bunch.
