Transfer Link Template Data to Object data
Hello All,
I have successfully been able to connect to an excel file and populate the data using a link template. My goal is to get the link template information over to object data. The image below shows the properties of 1 of my items.
I believe the link below explains this, but I can't quite get it to work. When I import the shape file back in, in creates autocad points with the information. The information is currently attached cad blocks. I know the picture below is the properties of a polyline, the object data on the blocks are too long to show in 1 screen capture.
https://forums.autodesk.com/t5/autocad-map-3d-general/transfer-link-data-to-object-data/td-p/3817934
I am using civil 3d 2015
Thanks in advance, and I will thank you again in the future
Dave
Murph_Map
Look at the ADEGENLINK command.
Murph
Supporting the troops daily.
