We primarily use the ECW format and not Mr. SID because we have ER Mapper.
To make SID files you have to us Lizard Tech's software since they hold the
patents on that file type. ESRI use to sell an extension for Mr. SID but
Lizard Tech has now taken over that as well.
As to the jgw file, that is just a world file for a georeferenced jpeg. It
is the same as a tfw for a georeferenced tiff. Map uses these files to
insert images in their correct geospatial location including rotation and
scale. I believe Terry explained how to do that.
Tripp Corbin, GISP, MCP
Associate Vice President, GIS/Mapping
ESRI Authorized Instructor
Keck & Wood, Inc.
(678) 417-4000
www.keckwood.com
(678) 417-4000
(678) 417-8785 Fax
"Dave C." wrote in message
news:4812766@discussion.autodesk.com...
> What software are you using to convert to Mr SID? Lizard Tech?
> I used to have a program called "tifin", (Air Photo USA) that used a
> registration file (tfw) to import images at the correct scale and
> location. I just downloaded some sat. imagery from TerraServer today, and
> it says to use the corresponding "jgw" file. How can Map use that file?
> Thanks,
> "Tripp Corbin" wrote in message
> news:4811106@discussion.autodesk.com...
>> Try converting the Tiff to either ECW or Mr. SID if you can. Not only
>> will this allow you to have a single image but you will also see vast
>> improvements in performance.
>> Keck & Wood, Inc.
>> (678) 417-4000
>> www.keckwood.com
>> (678) 417-4000
>> (678) 417-8785 Fax
>> "fred mechini" wrote in message
>> news:4810903@discussion.autodesk.com...
>>> Our campus digital photo is composed by 33 tiles each tile is a TIFF,
>>> about 60 MB.
>>> I wanted a single image so I used MAP to "glue' all images.
>>> Unfortunately MAP can not deal with any TIFF larger than 2 gigs.
>>> Is there a fix?
>>> Fred
